MrNatural22
?SW sunshine =⚡️⚡️lit up thru the darkness✌️
Curious about the Ecoflow MPPT abilities.
I have an Ecoflow Delta 2 power station whos battery is rated at 52v that I use Two Ecoworthy 18v Bifacial 200w panels to recharge with. The panels are connected in parallel because of intermittent shade patches. Panels are 18-22v. It charges the Delta 2.
Elsewhere, I also use two Victron 100/30 smart MPPTs in operation using Sunpower 325w panels with a VOC of over 60v on other systems with 12v LIFePo batteries. Too high for the Delta 2s 60v limit.
It has always been my understanding that MPPT CC brings down the panels voltage to match the batteries connected to properly charge.
BUT,
Can a MPPT also raise the voltage to match the 52v battery of the Delta2?
Does the Delta2 MPPT have boost capabilities to perform this?
Or is this the common ability of all MPPTs? And can the Victron CC MPPT do likewise?
BUT,
