Ecoflow or Bluetti with a 50 amp RV
rwcjr
Rather than rewire my entire RV I am thinking of getting 2 of either the Delta Pro or AC300max with their connections to supply 240 volt 30 amp AC. If I plug in an adapter from the 30 amp NEMA L14-30 to a 50 amp RV receptacle will it successfully power both halves of the breaker panel (with 30 vs 50 amps 120 volt)? The Bluetti AC300 seems to have a problem balancing the loads (which may be fixed). Will, you seem to be the only one who has reviewed the Ecoflow double voltage hub and so I bow to your expertise!!
I can't comment on the Bluetti, but yes for the Delta Pro. With the Double Voltage Hub, each of the two DP powers one 120V leg of the 240V split-phase. Do note that the Double Voltage does not automatically balance the load for you. So if you have a higher drain on one of the 120V legs, the DP supplying that leg will drain faster.
