hamm55
Long story short.....
- Jul 23, 2022
- 33
So I was in search of a way to integrate my new Delta Pro with my home automation system (Home Assistant) and found this integration on github which supports whats shown below. Requires HACS to be installed on Home Assistant and the app github repo to be added as instructed on the github page.
A big thanks to who wrote this if he is a member of the forum or otherwise! As always, software is a perpetual 'work-in-progess' and not perfect yet but its a great start!
I installed it and it looks like it connects directly to the local Ecoflow ip address and local api on your local network and not to EcoFlows web server. Info is text based but should be easy enough to add some dials, gauges, graphs, etc..... Fantastic!
https://github.com/vwt12eh8/hassio-ecoflow
.............From the github page..............
This integration is not included by default and must be installed by yourself to use it.
Two methods are available, and you can choose one or the other.
This integration uses a local API. Therefore, if the devices are not on the same network, they cannot synchronize their status.
Tested products
- RIVER Mini (Not impl)
- RIVER Max
- RIVER Pro
- Extra Battery
- DELTA Mini
- DELTA Max (#12)
- Extra Battery
- DELTA Pro
- Extra Battery
Installation
- Install as a custom repository via HACS
- Manually download and extract to the custom_components directory
