SolarUKWM
OK, I've been in contact with Pierre at Solar Assistant, who has advised how to fault find this problem and get access to the MODBUS raw values -- and it's not Solar Assistant that's doing this. SA has exposed the issue, but is not the cause!
From the MODBUS registers ...
At "middle load": this is mostly consistent.
IHD/Smart Meter shows: 1.48kW, 6.5A, PF 0.96
Kaiweets clamp-on: 6.9A
531/h213: 2359 (235.9V)
532/h214: 68 (6.8A)
Reported Grid Power on summary page: 1627 W
At "low load": "grid" is reported high, although "load" is correct
IHD/Smart Meter shows: 390W, 4.91A, PF 0.374
Kaiweets clamp-on: 5.1A
531/h213: 2366 (236.6V)
532/h214: 40 (4.0A)
Reported Grid Power on summary page: 972 W
Having done some more testing, I can now see some problems.
1) SA is correctly reporting what the Ecoworthy is sending.
2) For grid, Ecoworthy is reporting current and voltage, these are being multiplied in SA to get "watts" -- which is only true if power factor is 1.0, and here it isn't even close to 1.0. It's showing as 0.37, that's coming from my utility company's smart meter deep-dive menus. I trust those measurements.
However, for load side Ecoworthy is reporting the current/voltage so that the "v*a=watts" calculation works, almost as if there isn't a power factor problem in the loads at all. Suspicious, yes? Especially in bypass mode, where GRID and LOAD should be the same?
3) How on earth the loads appear to have a power factor that low ... ?
I'm pretty sure that's not my loads, and is something to do with the Ecoworthy being between the grid and load, doing something more complex than "just passing mains through". Something I clearly haven't understood!
So: I checked W/VA/PF for sets of loads with a KillAWatt meter, mostly switching power supplies hence none will be ideal 1.0
a) 37W 49VA 0.77
b) 2W 22VA 0.12 (mostly a laptop in standby, phone charger unloaded)
c) 150W 205VA 0.72
d) 147W 155VA 0.84
Total ...
336W 431VA (overall PF) 0.78
So it's not the loads on the output side. I need to do more digging into the Ecoworthy's behaviour it seems.
I think at this point @42OhmsPA suggestion of calling in some clarification from @Bill Young might be helpful!
How can loads with a power factor of 0.72-0.84 be appearing to the grid as loads with power factor of 0.37?
How does the grid side react so badly to this 0.37PF (causing it to report about 3x too high due) yet the load side reads fine?
532/h214: 68 (6.8A)
532/h214: 40 (4.0A)
a) 37W 49VA 0.77
c) 150W 205VA 0.72
d) 147W 155VA 0.84
Total ...
