gigadude
For that single case you would put a washer down first, then the bottom lug, then the fuse, then the top lug, then a washer, lock washer, and nut.
That's what I was thinking would work.
Do you think battening down the wires with p-clips would mitigate the risk of things flying around when the fuse blows? The whole shebang is inside a 12"x12" metal gutter, I have about 6" between batteries to bolt down fuse holders:
the blue sea holders are 8" long, if I mount them perpendicular to the gutter I'll have one end under the busbar. I guess I could mount them up top in the worst case.
