4 Nm is equal to 700 pounds of axial force. I think that's pleanty provided the terminals and busbars are squeaky clean. I noticed during the video once he torqued the nut to a certain point, continued torquing made little if any difference. I was hoping to see a torque wrench.What I find interesting at about 16:00 he gets 160+ amps with a finger tight connection. Does not seem to have excessive heating at that connection. I am thinking a bit less torque on these terminals would be just fine. Certainly more than finger tight but maybe 4 Nm is more than necessary.
I would not attempt to connect 2 cells in parallel with drastic SOC's. He was careful but I would not want to try this at home..The point I was making that I've run into this over-current problem in the past when I was in a hurry and can be overlooked if all you are doing is testing two cells. Things change when you are doing more than 4.
Yes I would like to see the experiment continued with 3 full or 7 full cells and adding the low cell last. Probably more amps will move but not 3x or 7x. Of course the test was staged to produce more amps. The initial test was more realistic for newly arrived cells and much less current was flowing. By all means check the voltages are close before you assemble a stack. Maybe connect them in order from lowest to highest.It was fascinating to see how we get away with paralleling a bunch of cells at first with just finger-tightening without any fireworks due to the really poor initial contact. No drama! Good on him for demonstrating that.
Constructing an 8-cell paralleled battery for initial top balance? Let's say you have eight, 280ah cells on hand.
You connect up 7 of them in parallel equating to the equivalent of a nominal 3.2 , 1960ah battery.
Attach the last cell. Do you think that having 1960ah on tap when you connect the last cell is a good ideal? Nothing stands out as you make the attachment going from a loose connection to tight. Busbar might get warm for a little bit, but one thinks nothing of it.
But now, if your cell is only rated at C3 max current, we have a problem. And a reason why cells on the end can be underperformers. It's happened to me when I got in a hurry and didn't charge my replacement individually first.
Just a precautionary tale to always take internet-guru advice with a grain of salt. Or at the very least ask yourself: "Is my setup exactly like his?"
If not, you can fall into the trap of promoting urban-legend. In this case, it would be "don't worry, I've proven that you can connect cells willy-nilly and not worry about it!". All that concern comes from old EV'ers who are just worry warts. Not so - just trying to save some headache$.
I haven't. I understand your point. Say one connects 3 cells in parallel with a full SOC to a 4th cell with a low SOC. Nope...not going to do it with even just 2 cells.Don't miss the forest for the trees here!
Don't just line 'em up and attach to each other one at a time. Pair them, and pair the pairs symetrically!
Now enter your standard top-balance routine. Huh, why didn't I think of that? Ok, thumbs up for the video.
