Redpineapple
THIS FIRMWARE IS NOW REPLACED BY FAAB-2525!
https://diysolarforum.com/threads/new-18kpv-12lv-flexboss-and-gridboss-firmware-9-28.113344
Old notes / bugs
Wish I saw this earlier. Really wish that EG4 had some sort of alert for new firmware and notified the end user when the log into the monitor center or Application
@EG4TechSolutionsTeam you might want to make this a popup on your portal... just my .02 cents.
Be warned! This update is full of bugs and kinda 1/2 baked! Read the bugs and change logs before going forward! There is no going backwards in firmware!
If you do update the flex boss, you will also need to update the grid boss firmware at the exact same time if you are running a grid boss system!
Updating the flex boss and also the grid boss may or may not default your settings on the grid box as well! Back up a configuration PDF of your settings before you touch anything!
New Firmware Patch Notes
Change Log
I have not updated yet but I saw it just now
**EDIT**
I've updated as of 7/15 and ran into some issues (along with other users).
A few bugs or unreported changes.
@Will Prowse have you tried this new firmware and if so can you make a video on the upgraded features?
@mciholas @TacoMeat - I'm wondering if this changed the fan speed stepping or if that's a future release (and they didn't mention it in the release notes). Please test and report back!
I'm tempted to try it especially since it has a weekly schedule now which is what I've been asking for / wanting for awhile.
Patching this will likely drop AC connections to / from the device so be warned.
Thanks!
Old notes / bugs
Change Log
FAAB-2122
2025-05-13
- Based on FAAB-2021
- 1.Add Weekly Setting function
- 2.Add the function of Sporadic AC charge power function, it will cause the AC charge power to fluctuate randomly between the set AC charging power and 2% rated power.
- 3.Optimize the response speed and stability in zero export mode in meter mode.
- 4.Optimize the restart logic that modify the CT/meter, battery type and brand will not be restarted.
- 5.Improve the issue of reading the RGM settings.
- 6.Improve the issue of power display on Micro-Grid mode.
- 7.Improve the issue of not stopping at the Stop Discharge Volt of forced discharge.
- 8.Improve the issue where the LCD display on the load power side lacked Smart Load power when the Micro Grid plus Smart Load mode were enabled.
- 9.Improve the issue of increased charge power when setting the Charge Last mode.
- 10.Improve the issue of abnormal load display in web page flow chart during parallel mode.
- 11.Improve the issue of getting phase lost warning when switching from on-grid and off-grid in three phase parallel mode.
**EDIT**
- A full power cycle may be required to fully update this firmware. YMMV - https://diysolarforum.com/threads/new-eg4-12k-18k-flexboss-firmware.108200/post-1496716
- For the FB21 the fans now come on at 4000 Watts and are not 100% going. There is a curve built into the logic now. This is not documented anywhere in the firmware release - https://diysolarforum.com/threads/new-eg4-12k-18k-flexboss-firmware.108200/post-1496741
- Charge from Grid seems to be changed or having issues where it will charge outside of the time slot. The entire "time based" features seem to need some work - https://diysolarforum.com/threads/new-eg4-12k-18k-flexboss-firmware.108200/#post-1496713
- The iOS / Apple EG4 app needs to be updated to show these new features
- If you use an outdated app to configure the inverter with the new firmware the app may undo / fight with some of the changes. YMMV / You've been warned.
- If you have a dedicated screen (FB21 for sure) the touchscreen does not show the new features. Only the web portal shows the new features for scheduling
- battery communication Sensitive issues if you are using a Gridboss. Any communication disconnects reboot the device
- Doing quick charge does not fall off the schedule the following day. The next day will have the same quick charge schedule time you had requested the day before. Quick charge is 1 hour of time that inserts itself into your schedule
- If you have peak shaving enabled you are not able to use quick charge. Peak shaving overrides the request. You must first disable peak shaving to quick charge
- If you have a Grid boss attached to your Flexboss / eg4 hybrid inverter you will also need to update your Gridboss firmware - https://diysolarforum.com/threads/problems-with-eg4-app-after-firmware-update.108256/
- I still see the GB Firmware as up to date for version IAAB-1300 (as of 7/18/25) but there may be a newer one? Trying to get clarification on this.
- TBD (I could go on... but their notes still need to be appended for what was fully touched
Thanks!
