cs1234
Solar Wizard
- May 9, 2022
- 3,603
Oh wow. No batteries and high surge loads? Ok, I can't fault the inverter for freaking out on something like that.He’s talking about using PV only for loads
He didn't say anything about frequency.So, if he's offgrid, why would @Luxpower_Gilbert say surges are affecting the frequency?
@timselectricThis most likely expected with off grid applications, if the load is not stable. High surge load will affect sometimes the frequency.
I see.@timselectric
I was referring to this post. Maybe I misquoted in my other post? I'm getting all out of order.
Can you go in to more detail about shutdown.The last 2 days my batteries shutdown because of high voltage. My 18kpv has worked great up until this point. I've read that clouds could cause a voltage spike that might throw the batteries over 100%. I use the inverter off grid. How do I lower the charge cut off to say 97%. The only cutoff % I see are ac cutoff and force charge cutoff %.
I sent you a PMThe last 2 days my batteries shutdown because of high voltage. My 18kpv has worked great up until this point. I've read that clouds could cause a voltage spike that might throw the batteries over 100%. I use the inverter off grid. How do I lower the charge cut off to say 97%. The only cutoff % I see are ac cutoff and force charge cutoff %.
LOL I thought about tagging you.I sent you a PM
The inverter gave several high voltage alarms before it went into a fault and tripped a battery. Different battery each time.Can you go in to more detail about shutdown.
Did you check BMS for any alarms?
Do you recall the voltage when the battery shutdown?
Did your inverter power off?
Grid connected?
i looked at your data of your system and it seem the inverter is doing its job to keep it at 60 hertz of all time...If that is indeed the case, this is poor design and not acceptable.
The SE inverter is current limited, but the connection to 18kpv could provide current that would overload wiring. If you are using the GEN connection there does not seem to be a output breaker to protect that output. You will want to have a breaker at the 18kpv side, 40 amps should be the correct size.One question I just thought of for planning my AC coupled install.
I have a disconnect (not fused) between my SolarEdge 7600h and the 18kpv... But no breaker/fusing.
Is that necessary? I can't see the SE inverter randomly outputting more juice than my panels can provide so in theory I am not worried... But I'm no expert and would rather protect my 18kpv if it's at risk.
Thoughts?
I recommend to put a breaker between the SE and 18kpv.One question I just thought of for planning my AC coupled install.
Thoughts?
NoDoes the 18kpv have any kind of soft start feature or precharge resistor to prevent arcs from current in rush when turning on the DC circuit? Without a precharge resistor many of us "enjoy" sparks on the terminals when turning on the DC breaker for the battery bank.
Someone replied to my post the other day that the 18kpv runs less hot in their laundry room that previously had two 6500 ex units.Has there been in changes to the fan control logic? It would be nice to make them run to keep the units cooler.
Perhaps a firmware option, the default "quiet" mode and then perhaps a more aggressive "always on" option?Has there been in changes to the fan control logic? It would be nice to make them run to keep the units cooler.
What about EG4 ?Well it's been 5 days since the latest firmware and I am pleased to say my clocks are now accurate, well done to Luxpower and signature solar for actually making the improvements requested.
Pm me I can help you out if your inverter is online. But you do want to make sure you don’t have any priority Charge First settings enabled that will put you in self consumption mode. Grid soft start you would want to disable. Fast zero export selected.Does anyone know how to configure to stay in EPS Mode. I want NO Grid assist (I see lots of problems when using that mode including feeding back to the grid, and using mostly grid power for low load levels when I have lots of sun and battery power...) and just want the old SBU mode I had with a pair of EG6548's. Right now, the only way I can get in this mode and stay is to cut the grid power....
Any luck finding the solaredge keyI'm in the process of testing this. I have SolarEdge p320 optimizers on the current setup with SolarEdge. I have been looking for a SolarEdge key, which will "unlock" the optimizers for use on any inverter. It disables SafeDC protection, which (as far as I understand it) is basically SolarEdges "Remote Kill Device" and in the process opens up compatibility. May cause code/permit issues for the crowd that cares about that!
My p320 optimizers aren't listed as compatible (they don't end in "i") because they aren't listed as having Ind-OP (https://www.solaredge.com/products/retrofit/power-optimizer-indop#/)....but after some digging I found a reddit thread that mentioned he unlocked my exact model with the SolarEdge key. There is no Ind-op mentioned in the datasheet for my optimizer, but literally stamped on the side of each optimizer is "IndOP".
There are ZERO places to buy this key in the US...so I ordered the key from some site in Austria a few days ago. No evidence of it shipping. I also spent 20 minutes on the phone with SolarEdge today to just try to obtain/buy one from them and made it nowhere. I'll have to try again.
I will report in, because the second I confirm this works with my optimizers I'm buying the EG4-18kpv and the new battery they just released.
ALSO, if anyone has a SolarEdge Key I will pay you a deposit to "rent it", or I will outright buy it from you. PLEASE.
