Were they able to provide 200 amp service to both locations? Is the transformer larger than a standard single home unit?My neighbor and I are the last two houses at the end of the line up the mountain. We’re both off the same transformer and both read 253v-255v consistently. No issues though with power, bulbs/appliances or inverter.
Just interested on a standard transformers ability to provide two locations.
US grid (ANSI C84.1) allows 2 ranges for household AC V.
Range A can be designed for 240V +- 5% (252-228) from POCO while the electrical makers (utilization) can design to +5% -10% (252-220). Manufacturers can choose to go +10, but not narrower.
Range B allows a couple V higher for both poco and manufacturer, but down to 208V for utilization, but doesn't apply to lighting loads.
My question for @EG4TechSolutionsTeam is why can't firmware be coded to disconnect grid relay if say grid V > 255V for x amount of time or some other reasonable figure?
Grid passthrough above 252V is non optimal since 254V is allowed, but then still passing through above 255V is a no no to put it politely.
Is there any room left on chip to add code that if grid V>255V, grid relay should open?
If this was me, I'd be calling poco just to have them come out and have a look at transformer just to be safe since it shouldn't be above 254V for extended periods of time.
Fnnwizard would that not require a full 200 amp relay controlled internal disconnect?
I get that the grid and load circuits can be broken by opening the manually actuated 18K pv Breaker/ disconnects, but can an 18K PV actually open the "full" 200 amp load and Grid circuits by itself?
I am showing my ignorance now, but thought these units only had control of their inverters output amperage not the full pass through rated amperage other than the manual disconnects?
ps. Have not seen a reference yet, but is anyone aware of a schematic or any tear down look into what's under the cover of an 18K PV.
After a full year no one has opened one up but understand, because that would nullify the warranty.
