AlaskaStartsHere
I recently upgraded my EG4 18KPV to FAAB-2021. My system has been running for nearly a year and I have never had any issues, but now I am getting a E019 VBUS fault that causes my system to go offline. It reset itself in 2-3 minutes and then power is restored.
I called Signature Solar and told them what happened. They asked what the voltage was on my PV Strings. I told them it usually ranges from 490-515 or so. They proceeded to tell me that the Inverter is only capable of using 500V and after that it will clamp it and may have tripped the warning. This is of course total BS. The inverter is rated for up to 600V and will only utilize up to 500V. I explained this and she then started to ask me about grounds, neutral/ground bonds etc. Funny how it went from the PV string voltage is definitely the issue to possibly a wiring issue on the 240V load side. I work in a support function professionally. I get it we can't know everything, but many times when I call SS, I get some BS. Come on do better.
Anyway, I keep having this problem. It doesn't appear to be load-related at all. I'm not starting anything high draw, or using any device that hasn't been used in the past year with the system. It appears to only happen when the SOC reaches 100%. This most recent time on 4/12 it happened twice within about 30 minutes. The system didn't even log a fault this time either, which is strange.
The previous time on 4/2 a fault was logged. VPV1 was at 502.9 and VPV3 was at 510.5 Note that at earlier before the fault the system showed voltages around 511 and 514 respectively so the voltage being "too high" wasn't an issue then and it was higher.
Does anyone who actually knows what they're talking about know what's going on? Is this just bad firmware?
BTW, I hate to dog on SS, because I have called and gotten some good people, but way to many times, I've gotten someone who only knows what the tech support flip chart says.
