So, I had this interesting problem today. I have:
- EG4 24v 5kwh battery
- Victron 100/30
- Victron 24/1200 Inverter
- Victron 24 / 12 AC Charger
- 24v to 12V converter from Amazon https://www.amazon.com/dp/B01LYK6G2Y/
I turned the battery off but when I tried to turn it back on, it would make a clicking noise and never came online. I did some more testing and:
- if the Victron 24/12 AC charger is on it will turn on with no problem.
- if I disconnect the battery cable, turn it on then connect the cable, ithe battery will go into fault mode.
The 24v to 12V converter was only powering a set of lights (6 LED light about 35w). If I leave only one light on, the battery turns on fine. I did the process of elimination by removing all 24v fuses from the fuse box and the issue does seem to be related to the 24v to 12v converter. The issue only happens when it is active and under some load. Does anybody has any insights on what is going on? I do seem to remember somebody mentioning that this converter has some issue, but I was not able to locate the information.
Thanks for any help
- Victron 100/30
Thanks for any help
