Hi, I’m trying to setup a small off-grid system with 900w solar input into EG4 3k inverter and EG4 5kWh battery.
I’m able to get the battery and inverter to work, but when I connect the PV input I’m getting 110v input but no amps.
I checked the solar panels and I see volts and amps from the panels.
I have 3 Silfab 370 HC in series.
Total VOC is under 500v, but total current is over the 18amps max draw.
Anyone know if this is the issue?
Is there limit on the amps input, I would expect it to cap at 18amps.
Any help will be much appreciated.
Many thanks.
Many thanks.
