coppergenie
Hello!
I have a 3000EHV-48V AIO inverter that's been connected to a series solar array with disconnect switch, all working properly for months. Today suddenly the AIO was not recognizing any power from the solar array, but still works with battery.
There is a warning on the inside cover of the AIO that says not to connect PV power while the AIO is running, which I am sure I may have done a few times because this label is on the inside cover, and I forgot about it. What effect might this have?
Notes:
- I have cycled the AIO and battery
- No grid power connected
- LifePower4 48V 100Ah battery powers the AIO fine
- Typical maximum input is: 180 V, 5 A, 900 W
- Panel specs: 4 in series, P_nom = 345 W, I_sc = 9.6 A, V_oc = 46.6 V
- No open circuits detected along the PV series loop (only checked visually)
- Screw terminals are tight for PV input on AIO
- No faults or error codes show up on the AIO display
- No new odors or sounds near the AIO
- Support request sent to EG4, still waiting
Any ideas to what may be wrong and how I can troubleshoot? I have a prong and clamp multimeter.
Notes:
