JD McGyver
- Jun 20, 2022
- 13
I am making a solar-capable portable battery backup solution using two EG4 Lifepower 48v batteries. I have purchased the batteries and the EG4 3kw Off-Grid inverter. Also the 18A charger. This is to roll around the house for portable AC and power my home workstation or fridge/freezer during grid down. Plan on using a 4 wheel "furniture" dolly 18x30 as the platform from Harbor Freight. I have seen a youtube video for County Living Experience where he charges each battery in his stack/server cabinet individually with a small generator. I believe that was to top balance each one to even out some variations.
Since I only have 2 batteries, can I use the 18A charger to charge both at once from the 110V grid or a generator? Or do I need to disconnect and charge individually?
Also. With anyone using the 3kw EG4 inverter, I THINK I understand that I will need a minimum of 120V solar input to even start using the charging ability of the inverter. Speaking to Signature solar, they said 160 was recommended for less sunny days. Does that mean that on very cloudy days I will get nothing if the solar input does not equar at least 120v from solar? I currently only have three 100V panels and would prefer not to have three or four rather large 40x80 panels as part of a "portable" solution should I move this solution anywhere other than my home.
Also confusing is that I read/heard that these batteries should be limited to 18A charging. How does the inverter have 80A charging ability when the external chargers are limited to 18A. I see from the forum that the 25A chargers or not currently available on the Signature website and that some folks have had some issues with those.
Any expertise would be appreciated!
