I'm using the alligator clips provided with the charger to the main positive and negative of the battery pack. The charger is plugged into an extension cord connected to the 120v, 20amp outlet of the generator.
When I start the generator, the charger will trip the breaker after a minute. When I reset it, the charger will run for around 10-20 minutes until it trips the breaker again.
The max input current the charger uses is 16 amps, so it is weird that it trips a 20 amp outlet.
Charger: https://signaturesolar.com/eg4-battery-charger-48v-18a-1/
Any help would be appreciated!
