Eg4 48v 18ah battery charger is tripping 6500 Predator generator.
How did you determine that it pulls 16 amps@120VAC?
Here is my napkin math.
18 amps @ 55.2VDC = 993.6 dc watts
993.6 dc watts / .75 conversion efficiency = 1324.8 ac watts
1324.8 ac watts / 120VAC = 11.04 amps
I said the max amp usage from what I see on the sticker is 16 amps.
I like to know how they come up with >95% effi.
Input @90Vac (worst case) x 16A = 1440W
Output 58.4V x 18A = 1051W
OP needs to get Kill-A-Watt and take the measurement.
1440 watts is 80% of a 15 amp circuit.
Exactly what we would expect for a continuous load such as a charger.
That makes the efficiency ~73%.
I will not be surprised, I wonder if EG4 has validation engineer, or they just believe the Chinese supplier without questioning.
Didn't they have issue with these chargers before that did deliver the output per spec?
I see their ad in Youtube, but now I'm not so sure they know what they are selling.
It looks like Ben will be busy cleaning up the mess again.
I think their 48V 25A chargers didn't output enough current as advertised.
Yes, there are threads about it.
Note the specs don't say "continuous". The specs are likely the best possible performance for a millisecond under perfect conditions. That's how typical low end Chinese manufacturers (and their resellers like EG4) spec their inverters and chargers.
I did a test just now with one unit. It's 9.0A @ 117VAC continuous input with my batteries at 51.7V right now. So 1,053W. This is fine for me and basically what I expected.
I'll try to check again when they are closer to 48V.
Do you have the same charger as OP?
What is the charging current when you see 9A on the AC side?
