I'm wondering if anyone has any thoughts on why an EG4 3k invertor is immediately throwing a 6P fault code, meaning "output voltage is too high". Use is strictly off-grid/backup power not connected to AC input voltage. So far I have 1 Lifepower48v 5.12kwh battery and currently for test purposes 4 SunPower 327w panels. There is zero load on the 120ac output side but the system thinks the output is too high. This is what I gather, I may be wrong. I went though programming twice to make sure all settings were correct. Id apprciate any thoughts or suggestions as I'm new to solar
