marionw
Solar Wizard
In 2 days, you're the second person to write this and I'm wondering why since it just doesn't make sense to me. I've been playing with LiFePO4 for a very long time.
If you have good measuring devices and the cell is at least in decent shape, any cell in a series bank that registers a higher voltage is likely to have a higher real SOC. I've always found this to be true, and when/if it doesn't, ends up cell is bad due to unusally high IR.
During charging, V descrepencies will be magnified so it becomes even easier to tell.
First of all, if htere are large deltas between high and low, it is always better to individually charge lower cell.
But if not possible, I would have no problem starting discharge balancer at even lower cell Voltages in the 3.385V area.
Why?
If cells were grossly out of balance, maybe they show the 20mV differential here but usually not.
I'm giving the cells a chance to get balance as quickly as possible by starting as early as possible. I bet if you set it at 3.350V, it likely won't balance because the mV delta would be less than 20mV.
The faster you can get it into balance the better for your pack since (depnding on number of cells that are off) the pack as a whole is operating with some cells 0-40%SOC, 40%-60%SOC, while others are 60-100%SOC for months!
I was told it wastes energy. But this is so relative it makes me sigh. Even if 15 out of 16 cells are being drained at 100mA at 3.55V, that's like 5W.
Compare that to what we are charging at?
Now if that pack was OVP due to a cell hitting >3.65V, how long would it be "off-line".
I was also told it would cause the cell to become more imbalance. If there could ever be such an event, the cell in question would be no good, and the mV differential setting would negate any "way out of balance" situation.
Now, once the cells are in balance, user can take it back to 3.45V balance voltage, but it really isn't even needed becasue now the cells will not see a 20mV differential until into the 3.5V area.
The only negative would be the BMS board heating up and the effects of that heat ( which may be nil if correctly designed).
But again, will only happen if mV settings are also breached.
There is no real harm in setting a lower staring V balancing point.
It's you battery and your party. 888888
