rfbuehler
Can I put 3 inverters in parallel (2) on L1 and (1) on L2.
This would give me 13K on L1 and 6.5 shared with L2 for 240v loads.
I would try with an amp meter to make share the loads are off balanced to L1. Basically I could monitor the two legs for a period of time one move loads between L1 and L2 to balance the system.
I will only have a Heat pump and heat pump water heater as 240v loads. The other heavy hitters, stove/oven, dryer, fireplace will be LP.
If I can do this vs 4 inverters it would be great 240w idle vs 320w would make a huge difference.
Also if you can remotely turn an inverter on/off can I turn one of the L1 inverters off say at 9PM and back on at 7AM, cutting idle draw to 160 thru the night when loads are low?
