SolarScott
- Sep 27, 2022
- 469
Trying to figure the best way to configure my system. I plan to have two transfers switches installed at my meter base....one that is between the meter and my main panel to my house. One that will go between my meter and the outdoor 200 amp panel that feeds my 5 ton heat pump. If I take my ac input to my inverters from the panel running my heat pump and leave the other transfer switch thrown to remove it from grid and have it use my solar out put, I believe the eg4 6000 can be set up to deliver all the solar and battery available and then make up the difference from grid. Signature Solar tells me that there is no possibility that this set up will back feed the grid. My only concern with this is that the transfer switch only switches the two hot leads, with an un-switched neutral. Also by doing it this way, if I am demanding more power than the inverters can handle I could run some of the higher loads from the 200 amp heat pump panel so they would be grid fed. Am I on the right track? Currently only have two EG4lifepower 48 volt 100amp hour batteries, two EG4 6000's, 24 455 watt bifacial Canadian Solar panels. I realize I will most likely need two or more batteries as money allows and maybe another inverter. Ideas?
