EG4 6000 xp no load power
RStone13
Amps X Voltage = Watts
I had powered down my xp 6000 & my power pro to due some wiring changes. when i powered back up there was no alarms of any kind but also no power from load breaker. I had cover off and was checking around for problem. On left side of 6000 xp is the switch that turns on ac power. Inside the unit is two wires that go to that switch, when I touched them I heard a beep and everything started working again. Problem solved , loose connectors on that switch
Maybe this will help someone
