My diy install is almost done pending final inspection. I am running 3 6000xp's in parallel and currently have 4 lifep04 diy batteries with jk bms. What charge voltage should I set in the inverter? Also will the 6000XP communicate with the JK BMS? I have all the bms's in parallel and communicating together. What settings would I need on the 6000xp in order for the inverter to communicate with the master jk bms?
