With the shorter days now and sun at lower angle, which is now causing some shading in the late day Im thinking about switching to battery eco mode. The question is if I do eco (Grid Charging is off) when the batteries hit EOD and the inverters (2 paralleled) go into bypass is there a setting to increase the 10% SOC increase before the inverters switch back to batteries? Im seeing it charge from 20% to ~30% then switch back and burn them down to 20% in a few hours (AC still running this late in the year). Keeping them that low seems to cause me grief with SOC drift then I have to switch over to Voltage charging for a few days to correct that. Id like to just stay in bypass until they charge up to 90% then go to battery mode, even if that takes a week with all the rain we are getting. Also if there is a way do I only have to set it on the master or on both?
