mattbrad2
I'm probably over thinking this, but I'm planning on having an eg4 6000xp as a grid assisted inverter to a critical load sub panel. I'll have about 8 circuits in this panel that will be completely separate from the main panel (both hots, ground and neutral). Originally I was just going to have solar panels feed a bank of batteries and this sub panel, while simultaneously having grid power the rest of the house at the main panel. I wasn't going to have anything connected to the grid input, but someone brought up the idea of having a 'grid assisted' mode where you would keep a 50A circuit to grid input, and let the grid could take over in fringe cases where we had a string of cloudy days and the batteries wouldn't be sufficient to carry the sub panel load. My question is how to wire up neutral in this scenario? With 4 wires to grid input and a shared neutral to the loads, you have a scenario where the inverters will be supplying ~25 - 30A from the batteries/solar to a separate load panel (with neutral shared with grid), while simultaneously having the grid power the main panel and using the same shared neutral. When you draw it out on paper it makes sense, but you're basically creating an unbalanced load to the main neutral wire going back to the main transformer. Neutral would effectively be the same return path for two completely separate outputs. This is slightly different than a multiwire branch circuit where your neutral going *back* to the main panel is potentially carrying an unbalanced load, and I know the transformer neutral is sized appropriately for these fringe scenarios - but it seems like I'm missing something obvious here. The alternative is having a triple pole double throw transfer switch where your switching both hots AND neutral to the subpanel. This seems a bit overkill if its in fact completely safe to just let both neutrals meet back at the main panel, where of course you'll have your only N-G-Bond.
