I just ordered one of these with two BABs (big ass batteries). I'm going to install as a home battery back up. A/C main will run to the 6000 and output will go to a subpanel with critical circuits. Two 280ah batteries in parallel will then power the critical circuits in the subpanel when power goes out. I have 14 solar panels that I can lay in the driveway for extended outages. QUESTION is where to place the generator input. The 6000 has a generator input and I could use that...but I would then want to backfeed the main panel from the subpanel and install a custom made interlock to feed say a microwave, washing machine or water heater if I wish. The custom made interlock would only allow 6000 to feed the panel when the main breaker AND the breaker feeding the 6000 are off. OR should I just feed the generator into the main panel with a standard interlock and forget the double wiring between the panels? Will generator/main power the 6000...thus charge batteries and run the subpanel? What changes with solar is added? Sig Solar couldn't answer how the A/C side worked--said they deal with D/C side of things. How does the automatic transfer switch control power flow in the 6000? Where does generator power input on the 6000 go? Thanks...
