Will do. Stay tuned, will shoot you a DM in 10days.Feel free to reach out once on-site, and I can update the dongle’s firmware and set the target location for its reporting to help minimize any downtime.
It’s true. The dongle is a separate computer that translates LAN to RS485/Modbus. The ethernet version was apparently built by a company that didn’t know about (or couldn’t implement) the port 8000 interface, so it doesn’t exist. This means SA does not work.I ordered the Ethernet adapter you mentioned. I'm going to be bummed if Solar Assistant can't communicate thru it. That sucks if true. Is there a work around ?
Correct, reserve on LANYou mean a reserved ip. A static ip is something else.
Looks like a usb problem.My 6000xp Dongle just went offline yesterday for a few hours, and did this twice. I thought it was just SA problem, but now today it happened again, and the EG4 monitor site also says offline, and the dongle is flashing 1 green light on the bottom LED. I updated firmware in the 6000xp about a month ago, and it has been very stable for 6 months. My router has not changed in any way in the entire 6 months. This is sudden and unexpected after SA and the eg4 monitor site have been so stable on this 6000xp inverter.
So there are at least 2 of us with this issue.
(Edit) and now 15 minutes later, it has healed itself for a few minutes, and then gone offline again.
Oh, wireless. You got another 2.4GHz device, or your neighbors WiFi is set to Automatic channel selection, or any number of things.I've moved my router from 25 feet away, to 10 feet away and I'm back online. But 25 feet away has been fine for 6 months???? I don't have any battery comms. Only set up as lead acid.
My SA is on a pi 3b wired ethernet directly to the router.
Are you meaning the USB on the 6000xp, or the USB on the pi?Looks like a usb problem.
What you can try is use a usb hub that have its own power supply
Try that .
I think by the update that the usb max ampère settings is change .
And that the usb shutdown.
I need one for the my Raspberry Pi with a fast wifi usb unit.
Not without losing the 'port 8000' connection in the WiFi dongle, which is what SA uses. Still not sure where SA is with their (beta?) hard-wired connections to EG4 gear, but I stopped caring when I went off and started writing my own software.As far as I know, a direct wired connection between the router and the 6000xp is still not possible.
My pi isn't using any USB, neither is my 6000xp. It's a wifi only connection from the 6000xp to the router, and a wired ethernet cable from the pi to the router. It's as clean a connection as possible until we can hook the 6000xp directly to the router via wired Ethernet cable. As far as I know, a direct wired connection between the router and the 6000xp is still not possible.
My 6000xp is from July and it came with 2.06 dongle firmware from the factory.
Did you update the DST? If you did is that when it stopped working?I've had my 6000xp wifi dongle (FW v2.04) connected for over 5 months and checking the monitoring app daily except when im there. Inverter is only 20ft from the wifi router. I wont able to give it a reset until my next visit. I can reboot my router remotely but didn't help. I know the inverter/charger itself is up and running because my other devices are remotely talking past few days while dongle has been offline. So...
-Are there any network setting on the dongle for reconnect attempts?
-Assign static IP?
Hoping next visit I can just manually push the dongle button for 5sec and it comes back online. Unless its dead
You can try this in the future.UPDATE: Well after a week offline somehow it re-connected itself and monitor app back online, how I do not know. EG4 team upgraded my dongle FW to v2.06 while its up. FW Fixes include wifi end user encryption and stability updates. So might be good to go. Still might assign static Ip on router next visit.
More than likely it is because somehow the remote port is not correct or has changed as shown here. Check it.You can try this in the future.
What does that do, Refresh the dongle connection? Will try in a few days.You can try this in the future
Don't mess with it...if its working. refresh just tells the server to check again.What does that do, Refresh the dongle connection? Will try in a few days.
I haven't changed anything nor Im I there to do a manual reset.
