SunFarmer
Hello Forum,
I’ve encountered a challenge as a result of building my new off-grid solar electric system. The EG4 6000EX-48HV inverter has some unexpected effect on Power-Line Communications (PLC).
First some background: I’ve been dabbling with home automation since the 1980’s. Initially I build a network using controllers and switches that communicate via the X10 PLC protocol. Power-Line Communications or PLC for short, is a technology where communication signals are super-imposed onto 60Hz AC power lines. This is useful for home automation where remote-controlled switches and outlets can be deployed without the need for additional control wiring.
The X10 protocol became obsolete and replaced by the much-improved Insteon PLC protocol. As my X10 devices aged-out, I replaced them with Insteon devices. Eventually my home automation network consisted of an ISY-994i controller and a bunch of Insteon switches, outlets and smart lightbulbs. It all worked pretty well. The ISY-994i controller would send ON/OFF commands out on the power lines, and the remote Insteon switches and outlets, if they were in a good mood, and there were no sunspots, would turn on or off as commanded. However, sometimes, for unknow reasons, the Insteon switches and outlets just would refuse to cooperate, wouldn’t turn on/off or provide status. When this happens, I make them take a time-out until whatever was interfering passes and things get back to normal.
Recently. the primary Insteon supplier has gone out of business. So now as my Insteon devices reach end-of-life I’ve been replacing them with new equipment that used the Zigbee automation control protocol. Zigbee is a wireless system which work very well, but unfortunately is limited to a couple hundred feet distance at best from the hub to the devices. Also, my ISY-994i controller has better scheduling option over the hub I’m using for Zigbee. Consequently, I now have a hybrid home automation network of Zigbee devices in the house and Insteon devices for longer distances outdoors.
But I digress… Here’s my current challenge. Right after putting my EG4 600EX-48HV inverter online, I noticed that my Insteon PLC switches and outlets were not working. During troubleshooting, I turned off the breaker in the main panel which supplies power to the AC input on the inverter. Please refer to diagram. With the breaker off, my Insteon PLC switches and outlets operated as normal, with the breaker on, the Insteon device do not work. Clearly, the EG4 600EX-48HV inverter is absorbing, squelching, or somehow attenuating the PLC signals. Right now, I have the breaker turned off on the inverter input while I sort this out. My Zigbee network is unaffected.
Now a twist, I can’t explain… I have an Insteon PLC switch which controls a heat recovery ventilator. I just moved this circuit to the off-grid side of the inverter and expected this Insteon switch to no longer work. But it still does. I don’t know why. Somehow, the PLC communication signals are getting through the invertor, even with the AC input breaker turned off!
I will eventually come up with a solution, but in the meantime, I want to share this experience with the forum.
