wired1
Can anyone tell me if the EG4 6500 EX48 will allow me to use Solar first, Grid second and Batteries third? I need my batteries for grid down only. Thx
Thanks, I'm guessing that's a yes I just spent the whole afternoon reading through 26 pages of discussion and was just looking for an easy answer after thatCheck the specs for SUB mode. (Solar, Utility, Battery)
Thanks, I found it in the settings: harder to do when you get old as a goat!!Check the specs for SUB mode. (Solar, Utility, Battery)
Sorry, I didn't have time to look at the specs earlier. So, I figured that I would tell you what you should be looking for.Thanks, I found it in the settings: harder to do when you get old as a goat!!
6500 Manual SUB mode selected :
Solar energy provides power to the loads as first priority. If solar energy is not sufficient to power all connected loads, Utility energy will supply power to the loads at the same time.
6500 Manual SBU mode selected:
Solar energy provides power to the loads as first priority. If solar energy is not sufficient to power all connected loads, battery energy will supply power to the loads at the same time. Utility provides power to the loads only when battery voltage drops to either low-level warning voltage or the setting point in program 12.
Yes, that's what SUB mode is.I dont think that what you asked is still really in the manual correctly. I happen to want to buy 2 of these and run in parallel so I looked at what you asked.
from what I read there is no exact wording for
SOLAR
UTILITY
BATTERY
while that does spell SUB for short, the manual of the 6500 outlines only Solar and Utility.
So SUB does not exactly explain that the B is for battery if S and U are not available. Are we to assume that battery is the 3rd backup device since the letter B is there?
Im guessing it's a misprint in that section of the manual. They have a U after the , which makes me think it's a misprint. Does the attached clear it up?I dont think that what you asked is still really in the manual correctly. I happen to want to buy 2 of these and run in parallel so I looked at what you asked.
SOLAR
UTILITY
BATTERY
You should be able to choose either - SBU or SUB. Depends on how you want to use it.Im guessing it's a misprint in that section of the manual. They have a U after the , which makes me think it's a misprint. Does the attached clear it up?
@RichardfromEG4
Settings 30-33 will help you achieve this.Related question... Do you know if the new EG4 6k split phase inverter will support charging the battery at a predefined time? For example, I don't have solar but would like to run part of the load during the day using battery but only charge the battery at night (like after 8 pm when I have free grid power). So when the battery loses power, it will just switch to grid and not charge the battery until later. I see some setting but not sure if it is supported.
EG4 6K Off-Grid Split Phase Inverter | 6000EX-48HV | 6000W Output | 7500W PV Input | 500V VOC Input | Split Phase 120/240VAC | All In One Solar Inverter
Signature Solar provides solar panels, off-grid solar systems, grid-tie, and hybrid systems. Quality solar inverters, bifacial solar panels, complete solar kits, solar batteries. Featuring brands such as EG4 Electronics with their solar battery, LifePower4 and EG4 LLifePower4 and EG4 LLsignaturesolar.com
Growatt 5k supports this but I have to buy an extra transformer for 120v
great. Thank youSettings 30-33 will help you achieve this.
AC coupling?Can someone from Signature Solar post an explanation and/or working guide RE AC coupling capability. (For use with existing Grid-Tie inverters)
A wiring diagram would be helpful to confirm how this feature operates.
Thank you.
