zorrotm
Hi, so I have two EG4 6500ex inverters and I followed SS's guide on updating. DSP firmware update went through perfectly, said 100% successful but then after inverter restarted the display no longer works and inverter shuts off in less than one minute. The second inverter, the one not yet updated, will turn on and display does work but it ALSO shuts off NOW in less than one minute. Prior to updating DSP on first inverter both inverters stayed on and ran fine with no errors.
Currently just hooked up to EG4 batteries with all load and PV off.
I contacted SS solar originally because the cable wasn't working but found out that it was a driver issue and an older laptop actually immediately downloaded correct drivers, so got past that. They have been responsive and I am sure they will get back to me. I just wanted to check if anyone else has had and resolved this issue. I am concerned it bricked the display or something crazy. I hope not :/
Thanks!
Thanks!
