Hi, so I'm working on my build which includes 2x EG4 6500EX inverters in split phase. I would like to utilize a double throw switch (on-off-on). This switch would allow me to direct power to my house from the solar or placing the switch in another position, it will allow me to power directly from the grid ignoring the solar system altogether. I have been looking at the various 100amp double throw switches and there's a double pole and a tripple pole. The double pole switches only the hots, i.e L1 and L2 are switched, whereas the tripple or 3-pole switches L1, L2 and N. Below are the 2 switches I'm considering. My question is this...if I use the double pole, it means that the neutrals from the AC output from the grid, AC input into the inverter and AC output from the inverter would all have to be tied together and bonded. Is this a safe configuration, especially when the EG4s go into bypass mode? Another option, which is much cheaper is to use one of the automatic transfer switches and set it to manual mode only...is this also a safe option to use? With the 3-pole switch, L1, L2 and N are switched so I don't have to tie all the neutrals together like how I would have to with the 2-pole...at least I think that's how it works.
2 Pole Link:
3 Pole Link:
ATS Switch Link:
https://www.amazon.com/Automatic-Tr...9Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
Thanks in advance.
2 Pole Link:
3 Pole Link:
ATS Switch Link:
Thanks in advance.
