I saw someone had a post on the 120 circuit flickering of lights. It worse with the LED bulbs but noticeable on incandescent and halogen types. I doesn't mater if I'm running on solar, battery or utility. My thought is that the inverter is putting out these blips. It can happen once in while or a couple times a second. Doesn't seem to be a rhyme or reason to the phenomena. Has anyone else seen this kind of thing? I have everything short of an oscilloscope and can't find abnormal readings anywhere. I've tried taking them out of split phase, Current sharing and even just running one, then the other as a stand alone. Same thing. Any thoughts?
