I have been trying to reach tech support for almost 6 weeks, using various contact methods. First issue, my inverters are outputting fluctuating voltages rangine from 105-133 v causing lights to flicker and other wierd things. Second, i think one of my inverters may have a faulty MPPT as it is not shoing up in solar assistant when monitoring. I have solar assistant data for about 5 days showing what i am talking about. It's been very difficult and extremely frustrating trying to reach someone there for technical support with these inverters. I have filled otu two "contact us" forms, two+ weeks ago and today. I have called multiple times and been on hold for over an hour with no answer on the tech support line. I have attempted multiple times to "keep my place in the que and receive a call back" and that hasn't worked, as the call either disconnects before confirming my number or i don't get a call back. I try to answer any calls that appear to come from a 903 area code, but other calls may go to voicemail as i get MANY spam calls each day, but if they are calling and not reaching me i would expect them to at least leave a voicemail. I have not received any voicemails from Signature Solar. I received one email from a person named Travis at Signature Solar on the 4th November about the error 61 battery communication problem on my inverter and his suggested fixes didn't work. When i emailed him back stating such i never got a reply. Then i tried to also get his support through email for the output voltage problem. I have not received resolution to any of these issues and have not received any email reply from Travis since his initial email on November 4, despite emailing him back TWICE trying to get help. I have also called the sales line, spoke with a very nice lady there who said she would "hand deliver a message for someone in Tech support to call me back that day" and i STILL have not received a call back. What else can i do to try and contact Signature Solar to get the help i need? I'm running out of options other than complaining on public forums and very much prefer to just get the system i paid for working correctly. Below is a sample of one of the voltage spike/drop periods from the 2p1/2p2 inverter setup i have.
Additionally, for some reason Solar Assistant is only showing inverter one on the MPPT2 graphs. I assume this is a problem because I am assuming each inverter have two MPPT controllers, and that solar assistant is capable of monitoring both. I can see both voltage a current on both PV inputs on both inverters on the LED control panel, so either solar assistant just isn't picking up the second PV string on inverter two, or the MPPT is not actually doing anything. *note these graphs are a different time period from the output voltage graph.
I can see where it does correctly dial back almost all PV power once the batteries are charged but why is inverter 2 not showing on MPPT 2 graphs?
Thank you for any help you can provide.
