Hi all,
I have had an off-grid install of an EG4 6500XP for about 2.5 years with two LL batteries. I had a few teething issues but it's been reliable the last couple of years. One annoyance however has been that lights flicker. It's especially noticeable when the microwave is turned on/off, but we've been adding new LED lights and converting old fluorescent lights to Lutron-switched and/or dimmed LED lights and it's starting to drive us crazy.
I recently read a few threads here about the 6500 and flickering lights and also became aware of the "upgrade" program and I'm wondering if this would resolve my issue?
For background, we have very low electricity usage in our off-grid cabin. Most of the time we are running sub-500w. Turning on the microwave or a coffee maker is the biggest thing we do and those each use around 1100-1200watts. When we turned the coffee maker on this past weekend, the lights started strobing like an EDM festival. I tried to take a video but it was the same frequency as the shutter so the phone didn't show anything!
Luckily, I did get videos that demonstrate the issue when there is no change in load and a change in load (e.g. turning on/off microwave), and for LED and fluorescent fixtures. We only have 4 items permanently plugged in: Starlink, Fridge, Ecowitt weather station, and hot water heater. I believe I have unplugged or turned everything off at the breakers to see if there is a dirty load but it did not change the behavior. Here's what it looks like:
Also worth noting is that we used a multimeter in min/max mode and found that the voltage is fluctuating as low as 115.8v and as high as 124.5 so about 3.5% (which seems within spec, but still might be part of the problem?)
I haven't contacted Signature Solar/EG4 about this yet as I wanted to get some feedback from folks who have considered or done the upgrade first.
Thanks!
- microwave turned on/off causes visual "pops" in lighting
- led lights flickering constantly
- different fixture/led bulbs flickering constantly
- fluorescent fixture flickering
Thanks!
