jjbillings
Hey all! I have an off grid system in my shop with 2xEG4 6000XP inverters and 6x48v 100ah eg4 ll-s batteries. I don't have solar connected yet, so I charge with a generator and chargeverter periodically (~once per week). Because the inverters draw a fair bit at idle, I turn the EPS Output switch OFF when I leave the shop for the night, which has served to limit the overnight discharge. Usually 1% overnight. Last night, I did the same thing I always do, turned the EPS off and left. SOC of the bank was ~33%. Came back this afternoon and all the batteries were at 0%!
. I double checked the data in the EG4 monitor webapp and it corroborates my own memory that the SOC was ~33% when I turned off the output. It also shows that the battery voltage was down around 47.5v at that point. So, I have two questions:
1) Did the batteries go from 33% to 0% so fast because the tail on the voltage curve drops off in the lower SOC percentiles? Or some other reason? Even with the inverters EPS off, they still draw a little bit (0.5-1amp).
2) I have the EOD cutoff on the inverters set to 15%. I _thought_ that this meant the inverters would shut off and stop drawing power at that point. However, given that the bank discharged to 0%, that doesn't seem to be the case. Am I misunderstanding that cutoff? Or is it a situation where EPS would need to be ON for the EOD cutoff to work?
