EG4 Firmware Updates – March 11, 2025
That's pretty bad over a month now and they haven't addressed that issue. I would be livid. Have you been in touch with them and have they looked at your graphs showing it?
That's assuming they know how to read a graph!
See this post of mine and the rest of the thread for laughs.
See markus' responses, the so called head of whatever at EG4, laughs at some of my posts. Some long time posters questioned my intelligence in there and constantly discounting the data.
Heh I skimmed through your thread there quickly, kinda felt like a woman in labour for 9 hours. ;)
I am still at ccaa-190D0E and until the upgrade is stable, I will be hanging out with the older update. No issues or problems that I am aware of.
Same with me just after i bought the 6000xp and installed it in Oct.24 I did 1 f/w update to 190DOE and it has been very stable since till now. I won't be changing anytime soon.
I never updated my 18kPV since I got it almost 1.5 years ago and haven't had issues (besides the noise) but I am off grid only so simpler installation.
1E1E seems to oscillate the load between two parallel 18Kpv inverters when the batteries are full, wonder if it’s related.
I ran into a similar problem after upgrading to the March firmware, with my inverter cycling once the battery becomes full. I probably should have read this thread first. In my case it's on a 12Kpv inverter. More details in this thread in case anyone wants to compare notes: https://diysolarforum.com/threads/e...n-battery-full-after-firmware-upgrade.103615/
Fyi, it turns out that my 12Kpv relay cycling issue, where the inverter puts itself into standby mode repeatedly once the battery is full, is not due to the firmware upgrade from 1C1C to 2021. We still don't know what the root cause is, but Signature Solar sent me a replacement 12Kpv, which is running 1C1C, and it has the same relay cycling behavior. I'll post more info in the other thread when we hopefully figure out what is really causing the issue. It works fine in lead acid mode, so that's the fallback plan if we can't figure it out.
yep. i wish i never updated past that
How is the latest version? there was supposed to be a new firmware released 2 weeks ago..
..I was just having coffee and heard a loud boom. It was one of my transformers recovering from a power cut from the 6000xp, I am getting really frustrated. I didn't upgrade yet because I didn't want the charge issues, but I don't seem to have many options left.
Also have you guys tried charging in lead acid mode to see if that fixes the charging issues?
My version is from February. It ocilates before float
I micro cycles the battery for like 3 hours
I didn’t see a LCD v20 link and instructions for standalone lcd + flexboss 21 combo. Anyone have it handy?
Just upgraded my 18kPV to FAAB-2122 to prepare to add my parallel unit, did it remotely from 2 miles away, it seems like it did 2 downloads, the last reboot was a bit longer than the first one. really hoping the parallel will allow seamless upgrades...
