Hi all, I'm trying to understand with the Flexboss21 - EG4 wiring diagrams show the Critical loads panel with a breaker size of 60-100.
Yet the FB will output 50A without PV present (just battery) or up to 66.7A with Solar combined with battery. So wouldn't the max size breaker for hte critical loads panel be 70A?
Or is it up to 100A because the FB will pass-thru 90A from Grid? - If this is the case, does it max out solar/battery first and then top up extra load from the grid or does it switch to 100% grid until the load drops back down to a manageable size for the battery/solar?
Second question if running two FB21 in parallel thru a combiner box would the correct breaker size for each be 70A?
Thanks,
E.
Thanks,
E.
