HFX
Hi all,
I apologize if i missed what i am asking, ( i did search i promise ) i installed our 12k EG4 mini split in march and bar a few teething problems it has been great and offset our electric bill a good amount each month ( hindsight i should have saved for the bigger one )
Finances stop much more of the plans to add more solar, and as the days are shortening now and its finally time to switch to heat, ( we are in alabama )_ id like to also have this wired to the mains for some early morning heat in the main living area and evening. ( as i have no batteries/invertor and financially can not get them and everything else entailed this year. )
Am i correct in thinking i need a breaker outside the house that connects to the mini split, then from the breaker to the panel and a 20amp fuse.?
my panel is around 13 ft away opposite the window ( red mark ) and i have a crawl space which starts to the left of the drain ( blue mark) and has access all the way around to the sub panel around 21ft total.
i know i should use 12awg wire, im sure i have to have some wire certified for wet conditions to the breaker from the mini split, but do i also need the same cable in the crawl space or will normal romex do?
again sorry if this is dumb or answered before, but if anyone could help with links/advice it would be one less stress for me.
thank you
Lee
thank you
Lee
