Hi
I'm considering installing some EG4 280AH indoor batteries. The manual says even though they are designed to be wall mounted they also need to rest on the ground to share the load of the weight of the units.
I've seen pictures online of units strictly wall mounted but I'm wondering if that is a practical thing to do, and if so what would be recommended/ideal.
Another option is to go with LL's 100AH mounted in a server rack, which can host 6 of them, making it double the capacity per linear space on the wall compared to 280AH which can be mounted one above the other. The issue with that, is 1. cost as the price per AH especially when taking into account the rack is 10-15% higher than the 280AH units. And 2. apparently even though the battery and the flexboss21 (which I will be using) are both UL compliant, they are not UL compliant when used together. (see page 2: https://eg4electronics.com/wp-content/uploads/2025/08/EG4-Systems-Battery-Wiring-Diagrams-2.0.pdf )
thanks!
thanks!
