I have two of these batteries connected to an EG4 inverter, and they have been working well for about a year.
I added a Victron SmartShunt about 6 months ago, and have been monitoring the SOC using that instead of the inverter values. I thought everything was working fine, but the last few days I noticed the SOC only got up to 67%, which has never happened before. I was away from the vehicle and decided to switch back to inverter values and that showed a SOC at 25%!
When I got to the vehicle yesterday the SOC lights on the one battery only showed one light and the alarm light was blinking. The other battery had two LEDs showing and no alarm. The low battery didn’t seem to want to take a charge, so I shut everything down and restarted both batteries. The alarm went away and it started taking a charge.
Any idea how the shunt got so far off compared to the inverter values?
Why would that one battery get so much lower than the other battery?
I’ve never hooked directly into the batteries using the BMS tool, and I currently monitor the inverter using SA hooked into the inverter.
Should I be doing something differently?
