Your handles should lay down fine after you place the pack in the slot and then the rest of the wiring goes on top as described.i am expecting a delivery for LL2 battery with the provided welded cabinet as part of the FREE.
hopefully i don't have same issue with the one posted here ... ?
Oh, I see the difference now. It's power from the battery vs just used energy. Got it!Ok, it depends on how we calculated. My point of view is, that I usually only need the battery at night time without solar (about 12 hours) to feed every load including the inverter idle energy. On daytime it will be driven by solar... so we are both right
I removed the top and side panels along with the batteries today and moved the vertical mounting rails on each side of the rack forward by two holes, then put everything back together. The batteries now fit with the rear panel installed. The only thing that isn't screwed in is the back of the 3 tabs connecting the busbars to the vertical rails on each side. These don't seem necessary since the tabs and busbars are connected to the front of the frame.We have been changing cabinet providers and the seamlessness has not been as easy as expected, we may be able to help you with this issue via credit or the orange cabinet as a swap, in the future we will be shipping all new yellow cabinets with ample room in front and back as well as the Panduit on the bus bar
LIFEPO4 battery site fire safety
NFPA 855 https://www.nfpa.org/codes-and-standards/all-codes-and-standards/list-of-codes-and-standards/detail?code=855 One thing about ESS systems that is often overlooked is the requirement to keep flammable materials over 4ft away in all directions. It's not as much about the batteries...diysolarforum.com
I was very disappointing in receiving a different cabinet (orange) from what was shown on the kits web page. Seams like bait and switch. Not having a gray plastic bus bar cover just makes it seam unsafe when having to turn on the batteries. Risk of touching both bars at the same time sound like and accident waiting to happen. I was hopping that this was a over site in the manufacturing, but I was informed the kits contain different cabinet from what is show and no covers are available. I am hopping to add some bar cover as soon as I determine the size I need.We have been changing cabinet providers and the seamlessness has not been as easy as expected, we may be able to help you with this issue via credit or the orange cabinet as a swap, in the future we will be shipping all new yellow cabinets with ample room in front and back as well as the Panduit on the bus bars
please use non-flammable floor and wall backer, 4ft radius of flammable items for fire protection is NFPA
Hi James,Your handles should lay down fine after you place the pack in the slot and then the rest of the wiring goes on top as described.
if you didn't order 2 cabinets then I assume the mismatch couldn't have occurred
Not happy either. SS sent me replacment bus bars and they have the same issue with turning inserts that is shown in this video. Waiting to hear back from SS.This guy was certainly not happy with his (newer version) of rack. Looks very dangerous:
I'm glad the one they sent me was the earlier yellow EG4 version, even though I had to move the front mounting rails forward to fit the batteries:
I encountered the same issue and solved it by flipping the mounting ears. This moved the batteries forward just enough to reinstall the back coverI just received the 6-space rack (pre-assembled) with the yellow logo and the Lifepower4 batteries protrude past the rear of the rack, preventing the back panel from being installed. I haven't heard of anyone else reporting this issue.
I have the same issues, also I have an issue with the black casters getting locked. The silver casters did not have that problem. See video link of the caster issue. https://rumble.com/v1qrloa-eg4-battery-rack-review-black-caster-pain-bring-back-silver-casters..htmlHi,
I've ordered 9 EG4-LL V2 and 2 EG4 6-space server racks by end of November 2022. After delivery, I've noticed that both server racks are different models. One has a yellow EG4 logo and busbars covered with cable channels, the other has an orange EG4 logo and no cable channels and they differ also in some other details. I've contacted the SS support by phone and they've told me, because one rack with 6 batteries was a special deal and the other batteries and the other rack was "standard" order. My first impression was - not nice, but I can live with it. Due to time problems, I only got around to installing the batteries last weekend. The yellow rack version worked great for the EG4-LL V2 batteries, everything fits. BUT the orange version has a huge problem with the EG4-LL V2 batteries. The distance between the front of the batteries and the busbars is so narrow, that the foldable battery handles touch the busbars and/or busbar screws (and yes, the batteries are completely inserted)!!! If, by mistake both handles would touch both busbars it would be really dangerous - this would shorten all six batteries in the rack! I could have accepted the also not matching mounting holes for the screws to fix the batteries at the rack, but the potential short circuit is unacceptable!
It looks like the orange version of the rack is NOT usable at all with the new V2 version of the EG4-LL batteries! I've contacted SS via customer support web form and asked for a replacement of the rack (swap from the orange to the yellow version) on Monday and looking forward to get an answer from them.
Have someone else noticed this problem?
FrankView attachment 132584View attachment 132585View attachment 132586
Thanks for showing the issues. My replacement bars are just like yours.Embarrassing:
Glad I have the original/yellow rack setup.
Frank,Hi,
The holes to secure the batteries to the rack are the same hole location as the handles. The handles need to be remove to secure the batteries.Hello,
We are supposed to only send the same rack version with any one order; this will be reviewed and we can support exchange or full credit on the cabinet. However, the new rack is compatible with the V2, here is the info:
Per the manual the battery rack: handles are to be laid flat and the cables installed above them.
Any work on the cabinet performed in the future should occur with all batteries de-energized; the handles are only for the purpose of easing removal/installation in a maintenance or upgrade situation.
We did see this issue at the time of the new batch arriving but in review, it is clear that placing hands inside a live cabinet is not a supported practice that we ever recommend. to recap, the proper sequence is:
1: install with handles down after securing in the slot,
2: connect wires to buss bars,
3: power off all packs before working with any hardware inside.
Hello Bob,Frank,
I had the same issue and Signature Solar put out a video and recommend you remove the handles before placing the batteries in the rack. I also purchased 2” shrink wrap to cover the bus bar because of the exposure with them.
I just removed the handles. Seems the easy solution. Side question: do you utilize that grounding lug shown in the bottom image?Hi,
