HighDesertOffgrid
Solar Pirate
- Sep 15, 2022
- 960
Correct. The 6000xp is "grid tied" as it can connect to the grid, pass it through, or use it to support loads and charge batteries., Thus, it's still a hybrid. However, it's not "grid interactive."Incorrect
A hybrid is the combination of grid-tied and off-grid.
At sea level on a 75 degree day out of direct sunlight, resistive loads only.just like marketing for gas generators: 10000 watts (surge-7500 continuous)
I have a 8000 watt winco generator, but I only use propane on it and I am at 5535 ft. It max's out at 6300 watts, only cost $50 because it was broken. It was a simple fix: replace the melted wire to the capsAt sea level on a 75 degree day out of direct sunlight, resistive loads only.
IncorrectCorrect. The 6000xp is "grid tied" as it can connect to the grid, pass it through, or use it to support loads and charge batteries., Thus, it's still a hybrid. However, it's not "grid interactive."
Thanks for validating the point, though. See, we can agree on something.
This is correctedit* you gotta love AI...
Incorrect
The 6kxp is not grid-tied. But it can be connected to the grid.
Grid-tied equipment relies on the grid to function.
Naw, I’m going to white-label the EG4 products and give them rational names for a 10%markup.Would be nice to have more competition in the market. If anyone here wants to start manufacturing I will cover it on my channel. Let's get it going
White label? Reminds me of the first generic products in the 70s. White can with black lettering that simply said, BEER.Naw, I’m going to white-label the EG4 products and give them rational names for a 10%markup.![]()
Correct , it's a hybrid. Which is a combination of both grid-tied and off-grid.Ahh, so the 18kpv isn't grid tied either then, since it also doesn't require the grid?
CorrectBy your definition, you are saying "a hybrid can use solar, battery, and grid at the same time"
Incorrectwhich, the 6000xp can do.
You are just being silly, now.It can charge the batteries from PV AND grid, at the same time. Thus, hybrid. Thanks for confirming yet again.
Not really. 150/75 doesnt mean 150v x 75AI mean, at least you know the important specs of a Victron 150/75 or 48/3000 without needing a cheat sheet.
ahh, moving the goal posts.. ie, changing the definition you set, to add "powering the loads" now. got it.Incorrect
It can power the loads by either battery or grid. (Not both at the same time)
The One or Rosie.How would you guys label them if you were in charge?
twice as much "fun"The 12000xp if definitely interesting.
or.....10 million lumen LED flashlight....requires 3 AAs.just like marketing for gas generators: 10000 watts (surge-7500 continuous)
Back to the actual news here if you all don't mind.
The smart ports on the grid boss are dual function, they can control output loads and can also receive AC coupling from other PV systems.
All inputs and outputs are voltage and current monitored so that the grid boss knows where to steer the power.
It is also rated to be a main service disconnect, it is going to be an extremely useful device.
The FlexBoss 21 is a slightly higher power version of the 18K PV but specifically designed to work with the Grid Boss, it does not have a display.
The 12000XP is what the off-gridders have been waiting for, twice the power of the 6000 XP and still has considerable surge ability. It is going to be very popular.
Indeed, without any other details, I'm hopeful for the GridBoss. Of course it'll come down to cost, integration support, and actual features, but it could be a valuable piece of new installs anyway.I'm pretty excited about the grid boss, if I understand correctly on it's capabilities. A while back, I responded to a thread where EG4 was asking what we'd like to see. I listed 9 things. The grid boss seems to address at least 3 of those wishlist things (33%!) 1,8,9 seems like they should all be solved with the grid boss. I'm already thinking of how I can make that a central part of my new solar setup.
In new installs, it also sounds like the one unit will satisfy the requirements for an external AC disconnect after the utility meter AND an automatic or manual transfer switch.. meaning saving costs and wall space.
I've been looking at various "smart panels", and trying to figure out a way to intelligently shed loads based on battery SOC, but haven't found one that is cost effective, or simple. It looks like most would require some kind of custom external control with a PLC or NodeRed or similar.
So for me, I'm REALLY interested in the grid boss. I just hope it's significantly cheaper than all of those insanely priced "smart panels"
The grid boss seems like it could be pretty useful. Fewer things to install when using multiple inverters. Looks like one of it's purposes is to eliminate the need for a few combiner panels.Approximate diagram of the grid boss, hopefully will give you some idea of what it can do.
That's a little better but:The grid boss seems like it could be pretty useful. Fewer things to install when using multiple inverters. Looks like one of it's purposes is to eliminate the need for a few combiner panels.
I suspect the 20-amp minimum on those smart loads is with regard to load shedding to conserve battery capacity. Perhaps they assume you wouldn't have a reason to shed a load smaller than that.That's a little better but:
Why the 20-xxx rating on the outputs? Doesn't work under 20A? Doesn't measure properly under 20A?
Are there two different versions for the 12Kpv and the 18Kpv? They seem to have 50 or 70A breakers...
It looks like these would then be in grid-tied mode to the GridBoss box? Sounds like a lot of thought is going to have to go into configuring everything properly, but does this also mean you could mix and match the {12,18,21}Kpv models? I can't imagine it wouldn't work in completely off-grid mode, if you just run everything off the Backed Up output...
I don't see the comms between the inverters and the GridBoss, but that's probably not currently documented?
I don't think it can do #9. The 18k is backfeeding via the grid input into the Grid Boss(AC connection PV to the Grid Boss). That requires UL1741SA. The 18kpv is synching to its grid input (the Grid Boss). The 6000xp, can't backfeed the grid input, not can it synch to it. The Grid Boss cannot combine the output of independent inverters that are not synched.I'm pretty excited about the grid boss, if I understand correctly on it's capabilities. A while back, I responded to a thread where EG4 was asking what we'd like to see. I listed 9 things. The grid boss seems to address at least 3 of those wishlist things (33%!) 1,8,9 seems like they should all be solved with the grid boss. I'm already thinking of how I can make that a central part of my new solar setup.
It seems like if you want the Smart Load capabilities of the Grid Boss, then the ability to independently parallel inverters is a nice bonus. I don't think there is much benefit to buying it just for that function.
The Grid Boss may be a smarter way to AC Couple a battery to an Enphase system. A cheap Growatt 10000tl-hu-us into Inverter 1, and Enphase into Inverter 2. Staying within the EG4 product line, what you would want is a stripped down 18kpv (or grid interactive 6000xp), and put the smarts into the Grid Boss.
Seems like a neat solution looking for a problem.
