Upper right click on the person icon, signout.I was not able to update it. On my phone, the app logs in automatically and I don't have time to get to the dongle button. How do I stop it from auto login?
Can you please send us a DM with the dongle's serial number so we can look into this for you?Upper right click on the person icon, signout.
I'm in the same situation: V2.06 but no encryption option. On V1.5.2 of the Android app.They are troubleshooting with me, I will post when I have a conclusive update.
This feature is currently not available for androids. This issue has been reporting. Once this issue is resolved we will let everyone know.I'm in the same situation: V2.06 but no encryption option. On V1.5.2 of the Android app.
Edit: meant to quote techguy but you get the idea.
It not available on Apple either, I tried.This feature is currently not available for androids. This issue has been reporting. Once this issue is resolved we will let everyone know.
Were you able to install the new dongles?It not available on Apple either, I tried.
If you try with apple again, let us know what app version you are using. We have not had any issues with apple users not having encryption available.They've not arrived.
Mine does not show on iOS either App Version 1.4.8 . DJ Series Dongle on V2.06.If you try with apple again, let us know what app version you are using. We have not had any issues with apple users not having encryption available.
The same. I installed the latest EG4 monitor last night on a friends Apple device. It doesn't show encryption options for the AP.Mine does not show on iOS either App Version 1.4.8 . DJ Series Dongle on V2.06.
The AP Parameter Section under Dongle Connect Parameters only shows SSID and Restart Dongle.
Wouldn't it make more sense to program things appropriately and unplug the dongles? That would let you benefit from the savings of the system.Until this is resolved I will be shutting mine down and bypassing the GridBoss and FlexBoss21 this is a huge security vulnerability.
What is the part number for a wired dongle? Until this is resolved I will be shutting mine down and bypassing the GridBoss and FlexBoss21 this is a huge security vulnerability.
I would recommend for EG4 to not manage my credentials, but use authentication from Google, Meta, Microsoft, etc, Identity Providers to manage the credentials. EG4 just uses the e-mail on the account to correlate it.While we are on the security topic the EG4 Monitor Center really needs to support multi-factor authentication as well, something like Google Authenticator standards (which work with many applications not just Google Authenticator) or similar would be great. SMS may be options as well for people who are okay with less phish resistant mfa.
I don't plan on using the system if a fix is not implemented within the week.Wouldn't it make more sense to program things appropriately and unplug the dongles? That would let you benefit from the savings of the system.
Good luck.I don't plan on using the system if a fix is not implemented within the week.
Good luck.
It's just the dongle that's the vulnerability, don't throw out the baby with the bath water. EG4/LuxPower is not the only system with these security vulnerabilities, it's a pervasive problem in the whole industry.I don't plan on using the system if a fix is not implemented within the week.
They posted this on July 2024. The settings are likely already there; they just havn't exposed it in the UI.It's just the dongle that's the vulnerability, don't throw out the baby with the bath water. EG4/LuxPower is not the only system with these security vulnerabilities, it's a pervasive problem in the whole industry.
If they could fix this within a week, I'd be even more worried about what other security steps did they skip.
Oooo! I will have my friend come over and try that! I looked for the LuxPower app in Google Play store, it's not there. I see the app still advertised as being available on Lux's web site. I wonder if LuxPower geo restricted it from the US for EG4.It is the EG4 Monitor app that is the problem. I downloaded the LuxPower app https://apps.apple.com/za/app/luxpower/id1415841608 and go to Dongle Connect and I can set the AP Password. This does not change any of the server settings. Even after setting the password which works in the LuxPower App the settings will not show in the EG4 Monitor app, as it's missing those settings completely. I think EG4 Monitor app latest updates have a regression in the latest code from LuxPower
That's disappointing... TKIP is breakable in less than 5 minutes with less than $100 in hardware. That's not security, that's theatre.Sadly it's still only weak TKIP not WPA2 AES once encrypted but better than nothing. I plan on looking to making a PowerShell script to set both encryption and potentially even just disabling the AP mode all together (as is normal). You would have to connect a system to the local Wifi connection from the dongle, not over your normal network as these commands get sent to 10.10.10.1
Still somewhat trival to get in but with no password for the Wifi SSID nor control we aren't even in script kiddie territory; we are in a kid messing around territory. or should I say "Blasted Meddling Kids!" - Scooby doo
Agree, I'd much rather be able to shut down the AP and Bluetooth interfaces. If I needed those back, factory reset the device. It's easy enough to reconfigure and that's the way almost every other device like this on the market works.So in summary: EG4 needs to check their current modified code base against LuxPower for a regression that happened in recent updates. Also it would be great if EG4 had the option to just completely disable the AP mode, I understand a reset would be needed on the dongle to change wifi or get back in that way but I think to many people this would be worth it. Looking at the LuxPower APK Code in Jadx this looks like it might be possible but it is currently disabled.
I really wish the Ethernet adapter supported TCP port 8000, I'd have already ordered that and moved on from this subject.
