timselectric
- Feb 5, 2022
- 25,189
California pregnant woman, please drop your suitcases and run away faster.
Me I don't know shit about any of that... none of my gear talks to each other and as such it simply works, & the NSA/CCP cannot ask my equipment what I am up to at the moment.Sok doesn't have their own protocol, it uses pylontech, just like Eg4 and about 90% of all batteries..
Smells like bullsh*
? Tim you totally, and I mean totally lost me this time... toss a fool a rope and explain for me so that my life can have meaning again.California pregnant woman, please drop your suitcases and run away faster.
They can't ask mine either, however the equipment internally communicates perfectly fine with eachother..Me I don't know shit about any of that... none of my gear talks to each other and as such it simply works, & the NSA/CCP cannot ask my equipment what I am up to at the moment.
See post #141? Tim you totally, and I mean totally lost me this time... toss a fool a rope and explain for me so that my life can have meaning again.![]()
gotcha, i missed that one!See post #141
reary Shaggy? what BMS's do you use again...They can't ask mine either, however the equipment internally communicates perfectly fine with eachother..
External ( internet ) connectivity has zero to do with inter equipment comms
Seplos, again , inverters and BMS's cannot connect to anything outside my home unless I will itreary Shaggy? what BMS's do you use again...
to each his own, there is always a backdoor even apple phones can be forced open if they want to badly enough. mine are not online at all, and everything works without the need for communications between the individual units. if you cannot set the unit to do what you want it to do without it tying into another piece of equipment, then its crippledSeplos, again , inverters and BMS's cannot connect to anything outside my home unless I will it
again you assume....to each his own, there is always a backdoor even apple phones can be forced open if they want to badly enough. mine are not online at all, and everything works without the need for communications between the individual units. if you cannot set the unit to do what you want it to do without it tying into another piece of equipment, then its crippled
Can ya blame themSolark have been refusing any warranty as soon as they hear EG4 batteries are connected to their inverters.
Only if you consider slower charging better.better charging,
I don't follow this. Please explain.better automation possibilities and additional safety
First let me apologise I probably came off a bit as a heretic... because I am i guess... it bois down to if your BMS cannot do its job on it's own without help from something else, ehy use it? the same goes for inverters, SCC's anything. the whole IOT was a plan form the start to grab data that the big tech companies could leverage... as such I assiduously avoid equipment that cannot work by itself.again you assume....
everything will work fine without communication, however having that communication brings better charging, better automation possibilities and additional safety...
I CHOOSE to have comms because of above
and phisically breaking a connection means good luck on forcing... there is nothing to force...
Although it is possible a span air gab .... they would need to sit next to my house, and your stuff is just a vunerable to that as mine....
If someone would gather enough resources and interest in me to invest that, one can safely assume you have a different issue
Air gap (networking) - Wikipedia
en.wikipedia.org
1. There is no SOK protocol, they mean Pylontec....however it's spelled.From what I have heard, the issues arriving with EG4 batteries and Sol-Ark Inverters is due to them (EG4) incorrectly using the SOK protocol that they emulate in order to talk closed loop with Sol-Ark. Pretty sure this would not happen with an open loop comms configuration. The crux of the issue being that EG4 batteries somehow modifies something in the Sol-Ark it is not supposed to, and thus, their memory or filesystem gets corrupted.
I can attest to this. They got pretty good with support and warrant claims.Signature Solar executes RMAs for customers outside of the US all the time, this is not true.
I would sure like to see you have one,Oh good point, I don't have one yet. I have a pile of products on my bench for review but I don't have that one. Was supposed to have it. Will make some emails
you'll be fine with EG4 batteriesWow reading all this got me worried,
I got a Sol Ark , and I am thinking of which decently priced battery I want to put on it.
Had EG4 and Midnite powerflo in mind. Now I have to put Pytes in the mix
Make sure to look at Ruixu too.Wow reading all this got me worried,
Didn't see Ruixu in Sol Ark battery guideMake sure to look at Ruixu too.
I am currently looking at some Dyness.Didn't see Ruixu in Sol Ark battery guide
Well neither is EG4. If you're going to stick to the SolArk battery guide you'll be limited to a set of more expensive batteries where the vendors don't typically work with DIY people.Didn't see Ruixu in Sol Ark battery guide
Any battery with Pylontech protocol works well.Ruixu and EG4 both work well with SolArk.
Do what we say, or get the kill switch?And let's just remind everyone what is Solark's stance on non tested and approved batteries ???
