@EG4TechSolutionsTeam
@SignatureSolarSupport @SignatureSolarJess
I used to run an EG4 3000 inverter with 3 EG4 100Ah V1-Lifepower batteries with no issues.The inverter ALWAYS read 300Ah as it should! A few months ago I decided to upgrade, so I purchased from Signature Solar a 6000xp-inverter… a “EG4 V2” 100Ah battery along with with battery cables and a Chargeverter…. Once installed I immediately noticed that the 6000xp recognized all four batteries BUT was only displaying between (396-397) Amp-Hours on both the inverter as well as on the EG4 monitoring app.
I figured since each battery was fairly new but purchased a few months apart that I’d wait until they all ran through some cycles together to see if they would balance up to the correct 400Ah… Well 4 months later and it still reading “396Ah” So I removed the communication cable and tested it with the (3) v1-batteries located behind the master V2, and presto it reads 300Ah’s just like it’s supposed to!
Last week I finally called Signture Solar tech support. They said that this is “not” an uncommon occurrence with the new v2-battery. They said it was a communication glitch that would be corrected by simply accessing the EG4 monitor website and going into the settings and changing the Lithium battery setting from “0” which is EG4 batteries to setting number “1” And once the system reboots it will read 400Ah as it should… We’ll since I had them on the phone I hit the tech-support remote switch allowing them to do it for me. They changed the battery setting to number (1) rebooted my system two to three times with no luck.
The technician said he did this several times with other customers and it always seemed to work. He said he has to reach out to EG4 directly, well that was a week ago and I haven’t heard back from him. Does anyone have any idea what exactly is happening here and how to correct it? I’ve included some pictures. Thanks in advance.
