You didn't think diy was going to be easy and cheap did you?
You'll be hanging near the mid/ upper voltages with solar than the lower voltages in a fractional C use.
With that said you'll need to disconnect equalize time to zero.
Change to 400ah
OV Disc 14.4
Charge limit 14.2
OV Rec ?? (Don't know what rec is, "reconnect"?)
Equal charge 14.2 (need to set time to zero, no equalization with lfp)
Boost charge 14.2
Float 13.5 or 13.6
Boost rec ?? (Don't know what rec is, "reconnect"?)
Low volt rec??(Don't know what rec is, "reconnect"?)
Under volt rec 12.2
Under volt warn 12.1
Low volt Disc 12.0
Discharge limit 12.0
Equalize time zero
Boost time ?? Not sure how this equipment works.
I use a Magnum system which is a little different than these settings.
Sorry I can't help you more. I'm off to bed earlier day tomorrow.
