TerryTtibbs
- Mar 15, 2022
- 56
Elcheapo Hydraulic Hex crimper results, as expected...stick to Burndy mechanical indent crimps eh!
$50 Amazon hydraulic crimpers.
Metric 35mm copper lug Be stamped.
35mm copper 1500VDC cable.
Cut carefully with a dremel grinding wheel. Was a bit eager in the first half of the cut so the grinding wheel anealed a bit, but the second half of the cut was nice and slow.
These are the results.
In summary probably 20% less CCC with a few months of corrosion than the rated cable probably leading to some kind of firework display if pushed hard with a 3KW+ peak invertor.
Im sticking to my Burndy Dieless Ident crimpers for guaranteed pressure crimp each time.
Just thought I would try them as plenty of Ben Shillers on YT pushing them hard.
Wouldn't be putting these to use on any of my gear unless its bonfire night!
