magic8192
- Feb 26, 2021
- 69
Would this honeywell mixing valve and this mechanical timer work?
I have a 50 gallon commercial water with dual 180F 2500Watt thermostats.
It is the #1 power user in my home.
Rewire the dual thermostats individually and connect the mechanical timer to 1 element.
Set the thermostat for the water heater element on the timer to 180F
Set the thermostat for the water heater element not on the timer to 120F
Set the timer to allow the 180F element to come on at 10:00 a.m. and turn off at 3:00 p.m.
- Heat water during max PV
Set the mixing valve at 120F
