Wanting to set things up properly / safe. I have a Growatt 5000ES-US (non bonded neutral) Off grid model that will have AC from the main panel that is hooked up to a 50amp breaker on the main panel. I will have EG4 batteries going into the DC IN, and eventually PV in. I want to output the AC from inverter to a breaker box to have have multiple things tied into the system. How do I go about grounding the Breaker Box safely. Am I able to tie this panel into the same ground that the Main panel uses? Do I need to drive in 2 new 8' rods solely for this panel?
Or does the AC Input act as the ground?
