immortl
I am going to be building a structure to house all of my solar electrical gear this Spring. I am trying to determine the best structure construction method for my particular area / use case here in Western MT. The structure will be located at the base of a large hill. It will house the batteries, inverters, MPPTs and associated gear. I'd also like to keep the 10kw diesel generator out by it, thinking up against one of the outside walls. To start with there will be 4 Midnite Powerflo16s and 2 Victron Quattro 10ks.
The area at the base of the hill where the shed/bunker will be located is open grassland facing directly south. My thought it to put up a 12'x20' structure. I have thought of 3 options so far.
1. Stick built shed using 2x6 studs, good insulation, and hang rock board internally to hang the gear on.
Ideally though, I think I'd like to sink the structure into the ground/hillside for temperature stabilization in both winter and summer. It can get down to -20ish overnight for a few days a year in winter and summer time temps can see a spike over 100 for 3 or 4 weeks a year. The area is referred to as the 'banana belt' of MT and is not as cold as other areas. I will say in the summer the sun is intense and hot. This is where the idea of a 'bunker' comes in. I recently picked up 2 older mini excavators to dig the pole mounts with so digging out an area for the electrical bunker ought not be an issue, or so I think. The soil is pretty darn rocky and I'm not yet sure how far down it is to bedrock.
2. Concrete block structure sunk into the ground/hillside - been watching videos on concrete block cellars. Sort of have an idea how to lay the blocks, but definitely need some practice. Seems you run rebar in the walls and fill with concrete afterwards. Saw one video where they filled the sun facing wall with vermiculite instead of concrete to keep the heat out. Then coat the outside and inside walls to waterproof it. Would I have to finish the inside walls with anything else? Then I'd use concrete anchors to mount everything on the walls?
3. ICF (Insulated Concrete Form) structure sunk into the ground/hillside - also been watching videos on ICF bunkers and homes. Seems it's like big adult legos, perhaps a lesser learning curve than concrete block? Again, some waterproofing at least on the outside before backfilling. What about the inside foam walls? Put up rock board? Would I sink anchors only into the rock board or do deeper through styrofoam and into the concrete wall portion?
Anyone have any thoughts or ideas on the above or other possible options I haven't yet considered? Anything you'd do differently if you built a dedicated electrical structure again?
Thanks!
Thanks!
