Old_Skewler
Everything I seem to learn on the forums from my research or from reading from other posts, when I share with a co-worker Electrical Engineer he turns into a "no-go no-can't" convoluted response, which makes me feel like I can't move forward or make any progress with my project.
I can't tell if he is following the NEC codes to the dot OR if he is just not up to date with the off-grid stuff.
For instance, I just shared with him that I am finally ordering (1) SunGoldPower AIO Inverter + (1) EG4 48V 100Ah battery, to which he replied, word to word as follows:
It is extremely confusing and frustrating because I keep talking to forum members and reading about people successfully making these installations. I even asked the EG4 Supplier @RichardfromEG4 if I could use a third party inverter and no issues were raised.
Could someone with more experience read the quote above and let me know your thoughts? Should I be concerned about connecting a EG4 battery to a third-party inverter charger (SunGoldPower)?
A BMS takes the positive and negative wires from the inverter/charger and places tap conductors between the cells in a string to allow eddy currents to avoid the hotspots on the feeder lead conductors and also operate the liquid cooling/heating where applicable.
EG4 makes the BMS and provides a handshake to their inverter then the BMS controls the inverter preventing the battery from exploding due to heating. Using a third party inverter you don't have that and can cause a fire hazard.
The other option is hacking involves removing the EG4 tap board & the BMS module to one that is compatible with the inverter (when using a third party inverter). There is typically 8 tap conductors and 2 thermistors (temperature sensors).
This is one tap board option that is designed to work with scrap model x and S battery packs
https://stealthev.com/product/tesla-model-s-x-battery-module-bms-cell-tap-board-2/
I don't think you fully grasp that you can't use a third party inverter unless you due diligence to get a BMS connection proper. That is why I am suggesting using FLA batteries.
